1999 Chevy Suburban
11,000 MILES • 6 CYL • 4WD • AUTOMATIC
HOCKEYGUY
Vehicle would not start after sitting in office parking lot all day. No cranking at all. Just a click.AAA came out, checked battery, cleaned the connectors,posts, checked fuses. Still would not start.There is some electrical power because the hood light works.
Tow truck came out tried jumping it one more time.
Fired up and started. Turned the engine off. Would not start again with out a jump.
Vehicle would not start this morning even with trying to jump start.
Oct 21, 2008 at 3:18 AM
DLOBI
  • 125 POSTS
With good battery or jump off good battery if you are just getting a click then it is likely that the starter is the issue. It is possibly a loose or corroded wire or that the starter itself needs to be replaced.
Oct 4, 2019 at 8:47 AM
