1998 Chevy Suburban injector
260,000 MILES • V8 • 2WD • AUTOMATIC
NOGUEZ2003
I can start the suburban but the engine start to shake, there is no black smoke. Does not run that good. Feels like is going to turn off but does not. I have changed the wires of the spark plugs and spark plugs. Reinstall everything back correctly. Change the distributor cap. One of the spark plug is wet with fuel. I replace with a new one and did the same think. Can the cause of this be the injector going bad or is bad?
I would appreciated if you can help me out.
Feb 11, 2010 at 11:48 AM
  • 75,988 POSTS
The sparkplug that is wet with fuel does it have spark if so check the fuel injector, no spark could be an open sparkplug wire/coil etc
Feb 11, 2010 at 12:31 PM
