pressure regulator will not hold fuel to accurate pressure?
200,000 MILES • V8 • 2WD • AUTOMATIC
IJLINDON
just chanced fuel pump and fuel pressure regulator and pressure regulator will not hold fuel to accurate pressure .
Mar 16, 2008 at 4:03 AM
SQM
  • 6,383 POSTS
First make sure all the hoses are attached securely and you do not have any leak.
It is possible to have a defective fuel pressure regulator.
Make sure the seal for the regulator is seated correctly.
This vehicle should have 60-66 PSI of fuel pressure with the key on and engine off.
Here is a helpful video:
https://youtu.be/aITQclp7zIE
I have attached the diagrams for your reference.
Sep 16, 2021 at 1:56 PM
