1998 Chevy Suburban engine runing too rich
127,565 MILES • V8 • 4WD • AUTOMATIC
HERBERT DYER
Trying to fix this problem quickly and cheaply, hoping it has a simple solution
Dec 16, 2009 at 8:56 AM
  • 75,988 POSTS
Hi Herbert Dyer and TY for the donation and we wish you a Merry Christmas and Happy New Year 2010.
Running rich is a fuel mixture that is too much fuel than air that can be caused by the following below
A bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Dec 16, 2009 at 1:21 PM
