1997 Chevy Suburban Whining transmission
145,000 MILES • V8 • 4WD • AUTOMATIC
MICHAEL DALE
Transmission whines until it shifts out of 1st gear. seems to shift at normal rpm's and doesn't seem to shift hard. whines till it shifts out of first and then whines slightly after i reach desired top speed (60 mph) and let off accelerator slightly. if i give it more accelerator, the whining stops until i let off the accelerator again. its not very noisy at 60 mph but, in 1st gear its pretty noisy. I just noticed this problem since the weather warmed up and i've been driving with the windows rolled down. i'm not really sure how long it's been making this noise since i usually have the radio on. I noticed it about a week ago, but may have been doing it longer.
May 5, 2009 at 3:28 PM
BIGZ
  • 21 POSTS
[quote:d4fa6e0a40="Michael Dale"]Transmission problem
1997 Chevy Suburban V8 Four Wheel Drive Automatic 145000 miles
Transmission whines until it shifts out of 1st gear. seems to shift at normal rpm's and doesn't seem to shift hard. whines till it shifts out of first and then whines slightly after i reach desired top speed (60 mph) and let off accelerator slightly. if i give it more accelerator, the whining stops until i let off the accelerator again. its not very noisy at 60 mph but, in 1st gear its pretty noisy. I just noticed this problem since the weather warmed up and i've been driving with the windows rolled down. i'm not really sure how long it's been making this noise since i usually have the radio on. I noticed it about a week ago, but may have been doing it longer.[/quote:d4fa6e0a40]
Its sound like the rear end to me jack the back up and move the tires back and forth and see if you hear clacking noise coming from the rear end.
May 11, 2009 at 7:57 AM
