I have a 1997 Chevy Suburban that I have been having some issues with. I was having trouble starting it so I Changed the plugs first, that helped a bit. A few weeks later I changed the Wires. After changing the wires, i started it up. It was still having a hard time starting. Then it developed a rough idle and low power output and the Check Engine Light came on.
I changed the Distributor and Rotor. That has helped with it starting but the rough idle/ride and lower power is still an issue. Please the check engine light is still on and occasionally blinks.
Helpppppppp....
Helpppppppp....
Dec 10, 2007 at 7:43 AM
