1997 Chevy Suburban stoplight switch
22,200 MILES • V8 • 4WD • AUTOMATIC
RICKTFD
My 97 Suburan is making my hair get greyer. I was having a problem with it getting stuck in park. I figured it was the brakelight switch. I took the switch off the rod and looked at it. I then put it back on. It worked. Next time I went to drive it, it would not come out of park. So I replaced the switch. It will come out of park one time and then not after that until I take it off the rod and then put it back on. I am totally lost on this one.
Jun 22, 2008 at 11:28 AM
BLACKOP555
  • 10,386 POSTS
replace the switch if you have not done so, and check the wires for damage in the wiring harness at the switch, moving it aroudn could be completing the circuit for a little bit, then going out again.
Jun 22, 2008 at 2:04 PM
