1997 Chevy Suburban only fires when key's released
21,000 MILES • V8 • 4WD • AUTOMATIC
HELPING YOU
  • 100 POSTS
Only does it COLD! You can crank all day - nothing - 'till you release the key - then vrroom! Been getting worse, fires when key's released but may not "catch" until many attempts. All is fine/normal until sitting overnight or all day. Ignition module? Other ideas?
Feb 10, 2009 at 1:22 PM
  • 110,248 POSTS
Hi:
It doesn't sound like an ignition module, but rather more like the ignition switch itself. Is the check engine light on?
Feb 11, 2009 at 10:49 AM
HELPING YOU
  • 100 POSTS
UPDATE;This AM I tried a 1 sec. blast of ether in the PCV tube hole - it fired right off! (fuel prob.)...
Feb 11, 2009 at 11:55 AM
