1997 Chevy Suburban I think I may have a miss
137,000 MILES • V8 • 4WD • AUTOMATIC
MWALKER80
When I am driving I think I have a miss at about 1500-1900 RPM, I have replace the plugs, fuel filter, and O2 sensors and it is still slugging at that rpm. I don't know what else to check please help
Feb 22, 2010 at 10:57 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensors.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor
Feb 22, 2010 at 11:47 AM
