1997 Chevy Suburban Check Engine Light indicates catalytic
166,000 MILES • V8 • 2WD • AUTOMATIC
TOMJN
I just changed plugs and wires. Engine light now on and readouit says catalytic converter problem, Bank 2. Could I possibly have leaned on something when changing plugs? I took the air cleaner, filter,etc. off and disconnected the MAP sensor plugs. When done I put everything back the way it was. The only problem originally noted was I reversed #2,#4 wires and went about 6 miles before fixing them. The O2 sensors and MAP sensor were replaced 2 yrs ago. Appreciate your help.
Jan 27, 2008 at 10:35 AM
BLACKOP555
  • 10,386 POSTS
first make sure your o2 sensor wiring harness is connected. Check your MAF sensor if equipped
Jan 27, 2008 at 10:51 AM
