1997 Chevy Suburban car will not start
KIM288
  • 1997 CHEVROLET SUBURBAN
  • V8
  • 202,000 MILES
My car will not start. I am thinking that it could be the netral switch, but not for sure.
Saturday, December 27th, 2008 AT 3:43 PM
Do below and tell me what happened
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, December 27th, 2008 AT 4:36 PM
