1997 Chevy Suburban CAN U HELP?
201,200 MILES • V8 • 2WD • AUTOMATIC
PDOF4
DRIVING ALONG CAR STOPPED RUNNING. STILL CRANKS OVER, HAS FUEL, 2 MONTH OLD FUEL FILTER...... WHAT COULD IT BE BESIDES MAYBE A FUEL PUMP?
Jan 9, 2010 at 4:07 PM
  • 75,988 POSTS
Hi pdof4, Welcome to 2carpros and TY for the donation and selecting us as your auto repair site Feel free to ask questions at anytime
Do below to determine if its fuel or spark issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 9, 2010 at 6:49 PM
