1997 Chevy Suburban burning up
210,000 MILES • V8 • 2WD • AUTOMATIC
CLG1957
front diver side break hung up and caught fire. I replaced everything at the wheel including ABS sensor and calliper. Truck ran ok for a short time then same thing - caught fire and melted th ABS sensor.
What would cause the break on that one wheel to apply and not release?
Nov 16, 2009 at 11:46 PM
  • 110,248 POSTS
Wow! I need you to check something. Can you compress the caliper piston? Also, have you ever replaced the rubber brake line to the caliper?
Nov 29, 2009 at 2:20 PM
