1997 Chevy Suburban 1997 Suburban will not shift into 3rd o
1997 CHEVROLET SUBURBAN
205,000 MILES • V8 • 4WD • AUTOMATIC
CJ_GREYWOLF
I have a 1997 Suburban with 205,000 miles. The transmission shift well into 1st and 2nd gears but as soon as it tries to shift into 3rd it slips out of gear and the engine RPM's ramp up. If I leave the gear selector in 2dn the transmission work great, but if I try to manually shift into 3rd it does the same thing. The transmission has been going through fluid since I got it about 5,00 miles ago. What do I need to do to the transmission to fix this problem?
Aug 21, 2010 at 7:40 AM
DOCFIXIT
  • 18,828 POSTS
Hi
3-4 clutch is slipping will need to tear down and repair. Pressure tests will confirm.
Hope this helps
Thanks for donate
Aug 21, 2010 at 7:52 AM
