Engine Mechanical problem
1996 Chevy Suburban V8 Four Wheel Drive Automatic
Drove vehicle, ran fine. Went to start again, oil spraying from under car. Checked filter...loose. Changed oil and replaced filter. Started the car and it blew the O-ring out of the filter, spraying oil everywhere. When starting, the gauge goes to about 65-70lbs. Why would a suburban have so much oil pressure as to blow the O-ring out of the filter?
Jan 31, 2010 at 11:51 AM
