1996 Chevy Suburban I have Electrical/ Fuse Issues
12,000 MILES • V8 • 2WD • AUTOMATIC
WALDO2910
My horn no longer works and i noticed the fuse was blown. Putting in new fuses does not work, the fuses will blow immediatley. My dashboard lights as well as my tail lights have the same problem with the fuses only lasting a few hours before blowing out. I believe there may be some bad wires in the car. I would greatly appreciate any input on my problems. Thanks!
Jul 15, 2010 at 11:44 AM
HMAC300
  • 48,601 POSTS
if your fuse blows like that you have a hsort someplace. if you have a trailer harness disconnect it to see if the tailight/dash light stops. if not take it to a pro. you could either have a bad horn or wire leading to it......
Jul 21, 2010 at 2:11 AM
