1996 Chevy Suburban fuel pump relay
178,000 MILES • V8 • 4WD • AUTOMATIC
BILLY107
I have gone through 2 fuel pump relays switches what would cause this?
Mar 25, 2008 at 1:46 PM
FISHERMAN
  • 937 POSTS
[quote:cb4f7d9d9e="billy107"]Engine Mechanical problem
1996 Chevy Suburban V8 Four Wheel Drive Automatic 178000 miles
I have gone through 2 fuel pump relays switches what would cause this?[/quote:cb4f7d9d9e]
What`s the time frame in between the replacement?
did you opened the relays?
I mean to see if the problem its the contact burn because a high current drawn or the coil burnt.
if the contact is burn (arching) could be a high current drawning Fuel pump or a short to ground wire..
let us know.
Mar 25, 2008 at 2:34 PM
