1995 Chevy Suburban water pump
176,000 MILES • V8 • 4WD • AUTOMATIC
JOHN5646
What are the steps in order to replace the water pump?
Dec 15, 2008 at 8:53 AM
ZACKMAN
  • 4,202 POSTS
WATER PUMP
Removal
Disconnect battery. Drain cooling system. Remove all drive belts, coolant hoses and mounting
brackets attached to water pump. If necessary, remove fan shroud. Remove fan and pulley. Remove
water pump and gaskets.
Installation
Install water pump with NEW gaskets. Tighten water pump bolts to 30 ft/lb. To complete installation, reverse removal procedure.
Dec 15, 2008 at 10:20 AM
