WATER PUMP
Removal
Disconnect battery. Drain cooling system. Remove all drive belts, coolant hoses and mounting
brackets attached to water pump. If necessary, remove fan shroud. Remove fan and pulley. Remove
water pump and gaskets.
Installation
Install water pump with NEW gaskets. Tighten water pump bolts to 30 ft/lb. To complete installation, reverse removal procedure.
SPONSORED LINKS
Monday, December 15th, 2008 AT 6:20 PM
