1995 Chevy Suburban Transmission
320,000 MILES • V8 • 2WD • AUTOMATIC
IMPORTERMAN
I have a transmission that was rebuild 20k miles ago. It will not shift into first or 4th gear after running about 5 minutes. I replaced the A shift solenoid and it changed nothing. Could it be the PCM and if so how do I reset, test or????
Thanks
Jun 2, 2010 at 5:05 AM
HMAC300
  • 48,601 POSTS
take it to a trans pro, he can scan it and see if there are any codes . It cold be a poor connection, or another bad part in the trans. Or it could be a bad valve body or anything actually. that is why you need to get it scanned first tosee what it says is happening.
Jun 5, 2010 at 7:52 AM
