1995 Chevy Suburban startup problems
240,000 MILES • V8 • 2WD • AUTOMATIC
MNORMAN145
I get fire to the distributor initially, then no spark. What would cause this?
Apr 19, 2009 at 7:45 AM
BLACKOP555
  • 10,386 POSTS
check to see if you are getting fire from the coil constantly. could be a issue with distributor. but more likely it is coil. check for spark directly from the coil to elminate lots of other components.
are you getting +12v constantly at coil?
Apr 20, 2009 at 11:44 AM
