1995 Chevy Suburban Sluggish in drive...
153,000 MILES • V8 • 4WD • AUTOMATIC
JBARNES68
When the engine is in park, engine revs fine and sounds strong. When put in drive, the vehicle is sluggish and hesitates. The map sensor and fuel filter have both been changed. Worked better after, but is now doing similar things. Any ideas?
Mar 12, 2009 at 12:13 PM
F4I_GUY
  • 3,302 POSTS
Hi jbarnes68,
Are there any check engine lights on? When is the last time you did a tune-up?
It sounds to me like you may have a mis-fire. A cylinder balance test may be in order to isolate this issue.
Mar 12, 2009 at 12:18 PM
JBARNES68
Yes, after driving a short distance, the check engine light does come on. But how come when it's in park, it will rev up and sound strong, but then hesitate when I start going? Sometimes when I'm at a light, still in drive with my foot on the break, it's revving all by itself. I'm a plumber and know nothing about cars...
Mar 12, 2009 at 12:31 PM
F4I_GUY
  • 3,302 POSTS
Get the check engine light scanned. The DTC will point you in the right direction.
The vehicle acts differently when in drive than in park because when the transmission is in drive the engine has a higher load put on it, thus making the mis-fire/hesitation present and/or more noticeable.
Mar 12, 2009 at 12:34 PM
JBARNES68
Thanks man, I'll find somewhere to have the light scanned. Hopefully that'll do the trick!
Mar 12, 2009 at 1:16 PM
F4I_GUY
  • 3,302 POSTS
Glad I could help!
Mar 15, 2009 at 1:37 PM
