I have changed the ignition module, pick-up coil, gas filter, gas pump, distributor cap, rotor, ignition coil, and checked the ground wire. It turns over strong and the engines never cuts out but it will all of the suddend not start whether the engine is cold or hot. Sometimes it will start after a few attempts and other times it will not start for days after trying dozens of times. When it starts, it runs excellent.
Aug 7, 2009 at 3:20 AM
