Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Suburban
Warning Lights
Airbag Light
1995 Chevy Suburban How do i do the Paperclip test on a 95
1995 CHEVROLET SUBURBAN
139,000 MILES • V8 • 4WD • AUTOMATIC
BIGTIMETRUCK
MEMBER
When I crank the car the airbag light flashes, then goes out so i want to find the code, to find the fault in the unit.
Oct 21, 2010 at 2:53 AM
DOCFIXIT
Experienced Mechanic
Hi If SIR is operating properly light will flash 7-9 times on start up. Need a scanner to read SIR codes. Can access PCM codes 12 pin jumper from A-B
16 pin jumper from pin 5-6
Hope this helps Thanks for donate
Oct 21, 2010 at 3:06 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
