1995 Chevy Suburban funny noise
1995 CHEVROLET SUBURBAN
180,000 MILES • V8 • 2WD • AUTOMATIC
LORIPACKARD
When you start the car it sounds like a hamster wheel (or rocks in a hub cap). When the car is moving and your not pressing on the gas it doesn't make this noise, but when you press the gas it will again. We did put some belt conditioner on the belt because of squeaking and this noise started right afterwards.
Mar 30, 2008 at 7:14 AM
BLACKOP555
  • 10,386 POSTS
drive slowly on a flat dry surface about 5 mph and turn the wheel left and right, do you hear a clicking noise or nothing?
Mar 30, 2008 at 11:22 AM
BLACKOP555
  • 10,386 POSTS
and does it do it while the vehicle is in park and you try to accelerate? same for neutral?
Mar 30, 2008 at 11:28 AM
LORIPACKARD
I did everything that you asked. When the car is in park and in neutral, when you accelerate the noise actually accelerates too. When going 5 mph it still makes the noise turning left and right. I did notice that when I put quite a bit of belt conditioner on this afternoon the noise went away for awhile.....any thoughts
Mar 30, 2008 at 2:48 PM
BLACKOP555
  • 10,386 POSTS
check your power steering fluid, and also take the drive belt off and wiggle all pulleys they should not wiggle or make noise when doing so also turn them all, they should be smooth not clunky
Mar 31, 2008 at 12:15 AM
