1995 Chevy Suburban faulty ignition?
200,000 MILES • V8 • 4WD • AUTOMATIC
CAPTAINJOHN
I have a '95 Suburban, with a six month old battery. Over the last few months, the car has started "sluggishly", with a hesitation almost like a near dead battery, but then when it kicks over, it starts right up. It's been getting worse until now it won't start. Battery appears fully charged, and the cables are good. The starter works great but only after it begins to "kick over". I think it's the ignition switch, but thought I'd ask an expert to see if this can be a problem with this year Suburban. When I turn the key, it clicks, again as if the battery were dying, but the headlights are bright, even when turning the key. Thank you for your suggestions!
Also, if it's the ign, is this something a back yard mechanic can fix?
Sep 30, 2010 at 7:24 PM
WRENCHTECH
  • 20,760 POSTS
You description is sounding like a bad starter but that really needs to be checked closer while the problem is present. If possible have someone hold the key in start position while you tap on the starter with a hammer. If that makes it start, then the starter is bad.
Sep 30, 2010 at 10:39 PM
