1995 Chevy Suburban Dropping Voltage at Guage
SURBURBAN OWNER
Electrical problem
1995 Chevy Suburban V8 Four Wheel Drive Automatic 149K miles
As head lights, AC (front and back), interior lights are turned on. Voltmeter guage begins to drop. Once below 10 volts on guage engine stalls, but will crank back up.
Battery and Alternator have been checked. 90 amps output under load.
Turning signal causes volt needle to drop a volt and only the inside head lights work on hi-beam. Is this normal?
Aug 20, 2009 at 8:17 AM
MERLIN2021
  • 17,250 POSTS
test this way, if it looses voltage, the alternator/regulator, or bad connections at battery exist!
http://www.2carpros.com/how_to/how_to_test_alternator.htm
http://www.2carpros.com/how_to/battery.htm
Yes headlight only have two high beams, not four!
Aug 20, 2009 at 8:20 AM
