1995 Chevy Suburban 1995 Suburban Transmission Fails to Shi
19,700 MILES • V8 • 4WD • AUTOMATIC
J CHASEK
The transmission shifts through all the gears just fine, but when it should shift into overdrive, the engine just continues to rev. If I let off of the gas to below 2000 rpm it will shift, then I can continue driving as normal. What should I do first? Last year I had the Dealer service the transmission. They replaced the oil and filter and I believe they flushed it as well.
Aug 17, 2008 at 4:49 AM
  • 75,988 POSTS
Do you have a steady check engine light on or comes and goes? Might want to pull the computer for code/s by grounding terminal B and comeback with the code/s. Also have the thermostat/coolant temperature sensor/vehicle speed sensors checked out-
https://images.2carpros.com/forum/automotive_pictures/12900_GM_ALCL_12.jpg
Aug 20, 2008 at 5:01 AM
