1995 Chevy Suburban
1995 CHEVROLET SUBURBAN
212,000 MILES • V8 • 4WD • AUTOMATIC
TIMOTHYSEIBERS
hey i have a egr problem when i rev the engine a little it pulls the egr valve open to much and the engine will almost stall but if i unplugg the the hose it will run fine but i wont to fix it the right way can you help
Sep 4, 2010 at 2:55 AM
HMAC300
  • 48,601 POSTS
check to see if your egr solonoid is sticking or staying on. If not then your egr may need replacement as the spring may be to weak
https://images.2carpros.com/forum/automotive_pictures/406719_egr_1.jpg
Sep 9, 2010 at 2:08 AM
