1994 Chevy Suburban replaced dead battery, cannot start wit
1994 CHEVROLET SUBURBAN
DEBPATTER
Electrical problem
1994 Chevy Suburban V8 Two Wheel Drive Automatic
replaced dead battery, still will not start. Is there something that may need to be reset if the battery gets too low/dead after the battery is replaced?
Apr 5, 2008 at 2:29 PM
JDL
  • 16,098 POSTS
When you turn the key to crank, can you tell if there is a load on the starter circuit? You can turn on the headlites, turn the key to crank, if the lites stay bright and there is no starter action, sounds like an open circuit. You might try to start it in neutral?
Apr 6, 2008 at 1:51 AM
