Truck sat for over about a year before I started to use it again, I would charge the battery while it sat and started it up every once in a while and would let it idle for about 1/2 hour or so. I planned on using it and it ran fine for about an hour and suddendly died on the street, no warning, nothing just died, some lights on the dash lit up some did not. Towed it home and sat for a couple of days, cranked it and started. Took it for a spin and it just died like before after about 5 minutes of driving. Fuel pump did not turn on, replaced it and truck worked for about and hour and again just turned off. I went to get the pcm codes and noticed no check engine light, checked the pcm in a friends truck (same year and model) and ran just fine. So I have replaced pick up coil, ignition module, main coil and nothing. I don't get a spark at the coil. Power is good to the coil. One thing to mention is I replaced the steering column after it broke down the last time and have adjusted the park/neutral switch at the base of the column. Thanks for your help,,,,
Sep 17, 2009 at 12:58 PM
