1994 Chevy Suburban Neutral Switch Location
1994 CHEVROLET SUBURBAN
165,000 MILES • V8 • 4WD • AUTOMATIC
MIKE79000
all the lights on my car are working other than the taillights and the dashboard lights. I went to O'reilly's and they told me the neutral switch needed to be replaced. I purchased a neutral switch but am unable to locate it on my vehicle. Where is the neutral switch?[img:0972d7209f]http://www.2carpros.com/forum/automotive_pictures/527906_2890101_1.jpg[/img:0972d7209f]
May 15, 2010 at 11:17 PM
HMAC300
  • 48,601 POSTS
if you look at the bottom of the steering column under the dash, you'll see it on the top side. Make sure your truck is in park when you replace it. there should be a small bolt/screw on either side of it. You may have a panel at the bottom of the dash to pull off to see it.
May 18, 2010 at 8:42 PM
