1994 Chevy Suburban Ignition
210,000 MILES • V8 • 2WD • AUTOMATIC
DOCVFR
Vehicle wont start. All lights and electrical components seem to be functioning. When the problem first occured. I could pull on the positive battery cable and when the key is turned, the truck would start. Now that wont happen. I have replaced both battery terminals and tried to jump the car. When the key is turned there is only a single click, and nothing more.
Dan
Dec 14, 2007 at 7:19 AM
  • 75,988 POSTS
Could be a starter problem. Check the 5amp fuse see below-if okay have helper hold key to start position and look for battery voltage on the purple wire at starter solenoid.
https://images.2carpros.com/forum/automotive_pictures/12900_fuse_5amp_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_starter_circuit_2.jpg
Dec 14, 2007 at 7:51 AM
