1994 Chevy Suburban Fuel system
MESTEVEZ84
  • 1994 CHEVROLET SUBURBAN
  • V8
  • 221,750 MILES
Engine won't turn over. Stalls when idle. Odd smell released from exhaust. Recently when in for a tune up. Spark plug wires were replaced, intake air filter, rotor, and fuel injector cleaner run through system.
Monday, May 24th, 2010 AT 8:04 PM
Check the fuel pressure if its within specs if okay, clean out the idle air control valve and PCV/EGR valves and test the throttle position sensor and manifold absolute pressure sensor.
Monday, May 24th, 2010 AT 10:18 PM
