1994 Chevy Suburban Any ides?
189,000 MILES • V8 • 2WD • AUTOMATIC
94BURBANBEAST
My suburban has been revving while driving in O/D for the past 4 months. If you laid off the gas you would be fine but the problem would persist unless you gunned it hard.
Now it is not getting into 3rd gear and above, at all. It will shift well through first and second but once it leaves second it never finds 3rd or 4th. It's like you have the truck in neutral and are stepping on the gas, and if not careful, red lining it.
Help please!
Nov 30, 2009 at 6:02 PM
  • 110,248 POSTS
This sounds like internal transmission damage. EIther the valve body is causing a problem or there is a clutch pack problem. You really need to have this checked by a trans mechanic.
Dec 6, 2009 at 10:59 AM
