1993 Chevy Suburban Possible ground issue or I do not Know
1993 CHEVROLET SUBURBAN
239,000 MILES • V8 • 4WD • AUTOMATIC
M_TITCHENAL
I recently replaced my engine in my burb and after the swap was done a new problem showed up.
1. Anti-lock light is on faintly
2. Wipers do not work ( at all )
Attempted fixes
1. Replaced wiper motor / and board
2. Replaced ground wires engine to frame and fire wall to frame and added extra for each
3. Replaced ALL Fuses on the panel
4. Disconnected Wiper/cruise control on column from wiring harness ( problem is still there ABS LIGHT)
Oddities
1. If I turn on the A/C the ABS light goes off ( still no wipers)
2. If I turn the wipers to high the ABS Light goes off ( Still no Wipers )
3. I almost forgot when I use the cruise and it catches, the guages all will twitch and then settle down.
Apr 27, 2008 at 11:51 AM
2CARPRO JACK
  • 11,533 POSTS
Is the ground hooked right to the wiper motor under the mounting bolt? sounds like a ground got left off or isnt getting good contact. Be sure the block/frame/body is clean where the grouund wires bolt up
Apr 28, 2008 at 12:57 AM
M_TITCHENAL
OK
After several visits to the local salvege yards to trace wires ( and not wreck my own ) I determined that the ground as you suggested was bad in the harness. I replaced the bad ground wire and now have a new problem. MY WIPERS WILL NOT TURN OFF!!!! When my sub is not running but the key is in the run position the wipers will run at a canstant speed. The other issue is that when the suburban is running I have 2 speeds normal or fast but they will still not turn off! HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
May 22, 2008 at 5:31 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like either the wiper module or the switch.They had alot of problems with the wiper modules in those trucks.Use a test light to see if the motor is getting power the entire time
May 23, 2008 at 12:24 AM
