Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Suburban
Brakes
Rotor
Replace/Remove
Having trouble removing front rotor from bearing hub
1993 CHEVROLET SUBURBAN
JSAUSAU
MEMBER
having trouble removing front rotor from bearing hub. this is a 2500 heavy duty suburban. any help will be greatly appreciated.
thanks,
js
Sep 25, 2009 at 1:11 PM
SQM
Experienced Mechanic
After all the bolts removed, you will need to use a wheel puller to remove the brake rotor from the hub.
I have attached the replacement procedure below.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Images (Click to enlarge)
Oct 14, 2021 at 6:47 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
