1992 Chevy Suburban throttle position sensor
1992 CHEVROLET SUBURBAN
10,000 MILES • V8 • 2WD • AUTOMATIC
HKI
If the throttle position sensor is bad would it effect
the performance of the fuel pump? giving me the
impression that the fuel pump needed to be replaced due to low output?
Sep 10, 2010 at 4:32 PM
The TPS has nothing to do with fuel pressure, if its low pressure problem consider replacing it-after you check the injectors and fuel pressure regulator are not leaking to include the fuel pump check valve.
Sep 10, 2010 at 5:03 PM
