1992 Chevy Suburban steering problems
198,999 MILES • V8 • 4WD • AUTOMATIC
SANTA VAL
I have a 92 sub, that wandered down the road. I changed the Pittman arm twice on this vehicle along with a tie-rod arm too. I had it aligned, with new tires. I thought I had every thing done. But it has just started to wander again it shows the Pittman arm loose again what is knocking out the Pittman arm?
Nov 4, 2010 at 4:41 AM
WRENCHTECH
  • 20,760 POSTS
Pitman arms don't just get loose. They wear slowly over long periods of time. There has to be something else wrong there that they are overlooking. One thing I have seen before is you get a lot of wear in the steering box and then they think they can adjust it out. You cannot do that because all it serves to do is disguise it a little and make it drive worse. Everything just needs to be examined closer.
Nov 4, 2010 at 5:04 AM
