1992 Chevy Suburban Brake Caliber Locks up
175,000 MILES • V8 • 4WD • AUTOMATIC
RARITAN
This truck has ABS brakes. Could a malfunction in ABS system cause the brake to lock? Would removing the brake fuse solve the problem?
Mar 14, 2010 at 12:26 PM
  • 75,988 POSTS
Best investigate the caliper pistons could be corroded and not retracting and also the brake hose acting as a one way check valve-And yes the ABS unit can be the problem
Mar 14, 2010 at 12:32 PM
