good alt. good bat. starts truck runs good use heater,lights,etc. battery drains truck dies?
Feb 27, 2010 at 11:24 AM
✓Experienced Mechanic
Hi there,
You will need to have a procedure called a current draw test done, this will check for any excessive current draw with the ignition turned off, you may have a stuck relay or faulty switch drawing down on the battery over night.
