1992 Chevy Suburban
FREDERICK D. FLETCHER
Electrical problem
1992 Chevy Suburban
Yesterday headlights worked fine, went inside walmart came out, started car,turned on lights nothing. My parking, signal,hazard,reverse, and brake lights all work.
Jan 22, 2009 at 3:10 AM
DOCFIXIT
  • 18,828 POSTS
What happens if you switch from HI beam to LO beam?
Jan 22, 2009 at 3:23 AM
JESSEJAMES405
  • 10 POSTS
Well If Nor your Hi or low beams do not work you might want to check the fuse for your headlights, and in that case if you have a "blow" fuse you might want to see if possible u might have bad Ground, Let me know
Jan 22, 2009 at 3:48 AM
