1991 Chevy Suburban valve body injection:
THE_HERB_MAN
Engine Mechanical problem
1991 Chevy Suburban V8 Four Wheel Drive Automatic
It won't start I changed pressure reg.& injectors ,getting fuel to valve body ,pour in a little gas it will run a few seconds and quit.Fuel seems to be going into the body but nothing comes out.
May 19, 2008 at 11:38 AM
BLACKOP555
  • 10,386 POSTS
hook up a noid light to the fuel injectors and crank the engine it should pulse, both of them. if light doesnt flash then check for +12 volts at one terminal with key on and hte other one should have none, if there is constant ground or no ground when cranking you could have a cks problem or a error with your fuel injector relay if equipped. and maybe even a bad ECM.
May 19, 2008 at 12:20 PM
