1991 Chevy Suburban sun roof
STANGDREAMER
1991 Chevy Suburban V8 Four Wheel Drive Automatic
I have a 1991 Chevy Suburban and it is new to me but the sun roof leaks and I know nothing about sun roofs,how they work what to check it is supost to be a tree position sun roof what ever that means
Sep 27, 2010 at 3:20 PM
MADMIKE1735
  • 951 POSTS
as long as the weather stripping is good, it may not be in the "park" position.... these sunroofs tilt either forward, or backward, depending on which way you press the switch... this was a common complaint on these when they 1st came out... you need to watch the sunroof when closing it, make sure it securely seats when you close it. you cant just press the button, and expect it to close by it self... that came after numerous complaints of leaking as you have described. hope this helps.
Sep 27, 2010 at 3:39 PM
