1991 Chevy Suburban Ringing noise
235,000 MILES • V8 • 2WD • AUTOMATIC
TRIBESMAN
I have a ringing noise(like small bell) coming from the bottom of the vehicle when I drive. It is sort of embarrasing as it sounds like an ice cream truck coming down the road. I have looked at every square inch of the bottom of the Suburban to see if anything is loose and can't find anything. I don't think it's the U-joints as they make a squeaking sound when they are dry, but the noise does seem to come from the rear end.
Jun 30, 2008 at 10:13 AM
MASTERTECHTIM
  • 4,750 POSTS
does it make the noise driving straight ahead or only on bumps? remove drive shaft and physically check rear u joints, sometimes they will throw you off because of the different noise.
Jul 1, 2008 at 12:08 PM
