How tight should the lock nuts holding the rotor in place be ?
Jan 11, 2008 at 10:40 AM
MASTERTECHTIM
✓Experienced Mechanic
not wicked tight. the best way to try to describe it to you is, first slowly snug the nut until the rotor has absolutely no play in and out then tighten the nut 1/4 turn and put in cotter pin. that should put you right on the money. i hope this helps
