1991 Chevy Suburban engine problem
88,000 MILES • V8 • 2WD • AUTOMATIC
RICHY469
i replaced the injectors and the regulator did the tune up but i unplugged the map sensor it only makes it idle better when i plug it in it stops the fuel flow but it does not kick the light on i tried to adjust the timing but it won't stay running when it does run it runs like crap any suggestions to help i replaced the map sensor and it does the same thing
Jul 28, 2010 at 8:39 AM
DVICTORIA
  • 6 POSTS
Have you fixed this or gotten any responses to your question?
Mar 21, 2011 at 6:03 AM
