i replaced the injectors and the regulator did the tune up but i unplugged the map sensor it only makes it idle better when i plug it in it stops the fuel flow but it does not kick the light on i tried to adjust the timing but it won't stay running when it does run it runs like crap any suggestions to help i replaced the map sensor and it does the same thing
Jul 28, 2010 at 8:39 AM
