Transmission problem
1990 Chevy Suburban V8 Four Wheel Drive Automatic
i have a 1990 chev suburban 1500 4 wheel drive 5.7 16 bolt pan 700 r4. a while back the trans started shifting hard, then go super soft, then back to hard. then it wouldnt shift till it almost redlined a couple of times then it will shift when u lift the pedal..then seemed to do ok..changed fluid and filter helped a little bit ..now it wont shift out of first even manually. this started after i put slick 50 in it..before slick 50 no problems at all..I KNEW BETTER..
May 16, 2009 at 6:35 AM
