1990 Chevy Suburban
1990 CHEVROLET SUBURBAN
BUICKMANW
Engine Performance problem
1990 Chevy Suburban V8 Two Wheel Drive Automatic
engine dies after water temp guage shows 195 but will start up immeadtly and runs ok for a 15 min time period has fire to plugs and hot wire to coil shows ok with test light fuel is going to the throotle body only happens when engine gets hot
Sep 27, 2008 at 3:50 AM
MERLIN2021
  • 17,250 POSTS
Check engine light on?
Sep 27, 2008 at 3:53 AM
BUICKMANW
no
Sep 29, 2008 at 8:30 AM
MERLIN2021
  • 17,250 POSTS
Get an ohm meter and test the ECT(engine coolant temp) sensor, should be over 10,000 cold and as it warms up, at 195 it should read 177 ohms...
Sep 29, 2008 at 9:34 AM
BUICKMANW
[quote:67b4b74abd="merlin2021"]Get an ohm meter and test the ECT(engine coolant temp) sensor, should be over 10,000 cold and as it warms up, at 195 it should read 177 ohms...[/quote:67b4b74abd]
Sep 29, 2008 at 11:48 PM
BUICKMANW
replaced coolant sensor didnt fik proublem
Sep 29, 2008 at 11:50 PM
MERLIN2021
  • 17,250 POSTS
I did say "test", not replace, you want to prove a bad part before you change it...
Sep 30, 2008 at 6:11 AM
MERLIN2021
  • 17,250 POSTS
Try unplugging, not replacing...the 02 sensors, these come online after the engine warms up, EGR valve too! TEST only, if it proves to be on of them then replace it.
Sep 30, 2008 at 6:13 AM
